Video card whine?
Gorilla
So I had TF2 running but with my speakers turned down. I notice that there was a sort of whining buzzing noise. I assumed that my speakers were making it, but no, it's coming from my case. If I minimize to the desktop the sound immediately stops. If I go back to the game the noise starts again. I turned off all of my case fans and had a listen. It sure sounds like it is coming from the vicinity of the video card. I don't think it's the PSU. It could also be the MB behind the video card, but the fact that it starts when I go to a game that uses the video card makes me think video card.
Is this a problem? Normal? I haven't had any problems so far, but it's worrisome nonetheless. Now that I have heard it it is actually quite noticeable above all the other noise from my case.
Edit: I did some searching and someone on some forum said that it can be caused by super high FPS. I had vsync off in TF2 and was apparently getting around 250 FPS. I enabled vsync and the noise was reduced dramatically if not completely.
Sounds like its coilwhine, I have seen this happen on both powersupplies and videocards, Go on youtube and search for it, they have videos that show you first hand what it sounds like. From what I have read, its not going to break your card but if its still under warranty it can be resolved in most cases by sending it in
Coil whine. Hate it.
It's hit or miss. I had 2 7970s (a XFX DD and a GIgabyte Windforce) and both had coil whine. Then I had an Asus 680 that was great... then I got my current Asus 7970 DC2T and it's nice and quiet... My friend had a Sapphire 7970 OC that he sent back 3 times and still couldn't get one that didn't buzz like crazy....
Good luck getting it resolved. I hope you have more luck than I have.
probablt because the are sending the same card back. i would put a very smaa sharpie mark next t a compoment so it looks like it belongs abd see if does indeed getbthe same card back. reason i say this is because in their eyes the card is probably performing @ spec :(
They weren't sending the same cards back that we sent in... I was able to ID them because of the pictures I took, and they sent different cards back each time. It's just a consistent problem. They behaved differently also.. I have some video of the noise they make and each one has a slightly different sound.
Sounds like Coilwhine when the card is stressed.
Last cards I had that on were my venerable 2x 9600gt in sli. Both cards had it for the first month or so, drove me crazy. Ran them overclocked @ 100% stress for a month to get rid of it. Kinda make it or break it attitude since returning them for coilwhine is a crap shoot.
Yes excessive, but it works.
