Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm putting together a new PC with and going from AMD over to an I5 Haswell. What would be a good upgrade from an HD6950 to what? I'm trying to keep it below $200.
If you are ok to mail in rebates this Sapphire R9 280 Tri-X for USD 215 (USD 200 after rebate) is a good buy. otherwise the Sapphire R9 280 for USD 175 (USD 160 after rebate) is a good option.
OP: if you can, i would suggest you stretch your budget a tad to accommodate the $250 R9 290s. I've seen many $200 ceilings that are just short of assuring serious bang for your buck.
In the end, if you can't stretch your budget, you have 2 options. You can go used on Ebay and hunt for sub $200 R9 290s (there are many) or 280Xs (all are well under $200), or you can stay NiB and go with the 280 or the 285 as suggested above.
Personally, i would scrounge up a couple extra bucks for the 290. It's a big jump over the 280 for only 50 bones more. As the resolution increases, the extra ram and bandwidth on the 290 will make that disparity even greater.
