Soarin
- Jul 23, 2010
So.. I can finally upgrade my 5770 to something better. Well almost.. waiting on my money yet.. Anyways, been looking and comparing. The best bang for buck seems to be AMD with the price/performance ratio. Budget is around 130, no more then 150. Cards I have looked into are the Radeon R7 260x,265. Radeon R9 270, GTX 750 Ti. My current mobo only has PCI-E x 16 2.0 slots though so I know it will hamper performance a tad. I did see a user on here that has R9 270x for sale for 130 used but.. it was used for mining. Never bought used and kind of iffy on it. So far I been leaning at the R7 265. Thoughts?
The PSU will be upgraded to a Corsair CX600 after I buy the GPU, depending on how much left over I have.
Buying the GPU will probably happen no longer then a month away. I assume sooner.
EDIT: Games I play, forgot to mention.. PayDay 2, LoadOut, World of Tanks, Terraria. There are more but forgot the names.
Specs: GA-880GA-UD3H Rev 2.0
Phenom II X4 955 BE
Gskill DDR3 1333 4gb
Intel V series 40gb SSD
OCZ Fataility 550w PSU
Phenom II X4 955 BE
