video card upgrade?
jester1176
I currently have 2x7900GTs on the following rig
M2N32-SLI Deluxe
AMD FX-62
Corsair CM2X1024-8500C5
how much benefit would I see by going to an 8800 series card? mind you, im running a LCD monitor with 1280x1024 resolution.
I would get an 8800GTS and you will see a GREAT improvement, the reason i dont suggest an 8800GTX is simply because of your resolution.
the single card should be able to perform as fast as those 2 put together not to mention you will be moving up to DX10 capable with the 8800
