Currently running a MSI geforce 9600gt and thinking it's time to upgrade to something new since I upgraded to windows 7. Plan on getting some new games soon like Civ5 and others and figured it might be time to upgrade. I usually upgrade every 2-3 years looking for a decent card that will hold me over for that time period. After price/performance I look for a model that is quiet.
My current system is
Antec p180b case
HX620w Corsair Power supply
Intel q8400 cpu
4gb memory
Asus p5k-e motherboard
Dell 2209wa monitor 1680x1050 monitor
So after some research it looks like a decent card can be found in the $100-200 price range I am looking to spend. From what I can tell the gtx460 and 6850/6870 based cards seem to fit my requirements but what brand/model should I look for?
Update - I also want to add I may upgrade my motherboard/ram/cpu in the next 15-24 months.
Antec p180b case
Intel q8400 cpu
4gb memory
