Video Card to Drive Dell U3011
isai95
Can you guys please recommend me an entry video card to drive a Dell U3011. I don't play any games or use any intensive graphics apps. So any very affordable card will suffice.
Thank you.
With no games or intensive programs, then you might be able to get away with using the internal graphics option on your MB or Intel CPU.
If you are looking for a low power GPU, then the AMD 7700 for around $100 is a good option.
Thanks for answering so quickly!
I checked but unfortunately my motherboard build in video card just goes up to 1920x1600. What about this one? I want fanless if possible:
http://www.asus.com/Graphics_Cards/AMD_Series/EAH5450_SILENTDI512MD2LP/#overview
That would work perfectly for your needs. Pretty much any discrete AMD or Nvidia graphics card from the last 5-7 years will support 2560x1600. There's no need to spend a lot of money if you don't plan on doing anything video intensive.
Heres that 5450 at newegg for $35. No need to spend any more than that.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121447
