Video Card Supporting 1900x1200 Resolution
Hey everyone,
I am upgrading my monitor and need to find a video card to support it. I plan on purchasing a 24" monitor. Most likely will be 24" Westy from Sams or the Dell 2408. Point being, both with 1920 x 1200 resolution.
Current System: Dell Dimension DE 051, Celeron 2.53GHz Processor
Current Display Setup: Intel 82865G Graphics Controller
New Graphics Card: __________?
Uses:
1) Very little to no gaming
2) Excel and other office software applications
3) Movies (99% downloaded off internet played using standard media player)
4) Youtube videos
Recommendation:
What do you recommend given my circumstances? My goal is to get an optimal or near optimal card to help the new monitor perform well. I am willing to consider a complete system upgrade. Please let me know if you think that is the direction I should be looking toward.
Budget:
~$300 USD or less for the card. I can afford more if absolutely necessary, but I am thinking it may not be beneficial.
lol 300$, this is a gaming card.
you will spend under 100$ ;)
can you check if you got a Pci-Express or AGP Slot on ur mobo ?
I have a PNY 7800gt 256 mb with Arctic Cooler NV silencer that supports 2560 x 1600 that I would part for $75. Oh yeah its Pci express for the motherboard.
I don't have a PCI express slot. I also don't have an AGP slot.
I have a normal PCI.
This throws a twist into the picture. Good PCI cards for one of the above 24" monitors? (Suggestions on a non-old school motherboard as well !?)
I think red falcon pretty well summed it up. I would go with the 2400 pro though if your into movies or want to go to vista (I am avoiding it all cost).
No gaming and if those movies are 700mbyte xvids (opposed to HD) then you need no video card. Your onboard should support 1900x1200 just fine.
If your wanting HD, a low end current gen or last gen card would be fine like an HD 3860 tops, nvidia 8600GT/ATI 2600 or even 8500GT/2400 with onboard video decoding would be good.
Edit: Seen that your PCI, go with the 2400 posted above then if your still planning on getting a card.
Though with a $300 budget for a video card you may want to think about just building a new machine, that celeron scares me... big time.
If you had a PCI-E slot (which from what I'm reading above you don't) I would have recommened the 140$ afterr MIR 9600 GT. Seeing how it can run nearly all the games these days as 1920x1200 w/o AF with settings at High or Very High. But that doesn't seem to be an option. If your not planning on gaming and just plan to surf the net and media player, well thats what onboard video was designed for.
I sincerely appreciate all the advice, especially now that I know about the best PCI card I can get.
The Celeron scares me as well. My current system was purchased in August of 2006 from Dell's build your own computer. It was a convenience and a budget buy. I think I will upgrade my whole system. I realize I'd like to upgrade my MOBO, the processor, the ram memory and the monitor. I think I can get all I need for ~$1800, which is the number that pops into my head when I think of a computer purchasing budget.
This is also key. I'll purchase the monitor now locally and do returns/exchanges until I have one that works well. I made an error in thinking my current card cannot support the montiors resolution (mistake made by checking display properties on current monitor and not finding 1900x1200). Subsequent to this I'll either buy a dell that I like or more likely will build my own machine. Picking out the components for that might take some time though. I'll more than likely use this site and a few other vbulletin board to find what I feel are the best overall components (when viewed as a whole system).
Update:
Just purchased and installed the 24" Westy. Apparently Best Buy and Sam's have both discontinued the model. I purchased the second to last one at Sam's for $366 and change total including a three year warranty.
My onboard graphics seems to work okay. However, when I download and replay youtube videos they lag. I suspect it is combo of several things causing this, including my processor etc. Overall very happy so far.
id say its the onboard gfx the prob
my radeon 9200se was faster than my Nvidia 7150 onboard gfx lol
If you need a new Comp, you can get a good one under 1000$
Gigabyte P35 mobo @ ~90$
intel e8400 ~200$
PSU ~ 60$
HDD Sata 70$
Case ~ 60$
Card ATI radeon 2600 XT ~ 60$ (I think)
2Gig ram ~ 40-50$
thats around 600$ and its a damn good computer for what you need.
That is a good idea WhDemon.
I am starting to look at components now. I suspect with my minimal needs that I can beat Dell's online prices building my own by a lot.
I am going to get a damn good processor that is for sure. Probably will go with 2G's of ram as suggested. Can't think why I would need more.
Pretty neat that I can get a card to do all I want for well under 100!
Of course spending $60 on a cheap PSU is probably not the best idea but if you don't do any gaming the rest is probably pretty solid.
Holy crap man! that computer ain't worth 50 freakin dollars. Buy a new comp. Anything and I do mean anything these days will handle that res. Don't waste your money on a video card.
Hi all,
Instead of creating a new thread, the OP had the exact same query as me - except I don't need PCI card.. I have a PCIe slot, and I don't require any gaming at all.
I have found this card here Sapphire Radeon HD 3450 - I see it is a lot cheaper, but will it still be fine for normal office working, browsing etc. (1920x1200) ?
Thanks!
my Radeon 9100 can do up to 2048x1536. Its almost 6 years old. As for your $1800 budget for a new computer, WOW! THats a ton considering you don't game. You could get a very fast dual videocard setup for way less than that. Since you just bought a new monitor, you could get a nice computer for less than $500
