jetablack4
- Aug 21, 2011
I pretty much figured out everything I want for my custom build that I will soon be starting and the last thing I need to decide on is my video card. I have been doing some research on cards and have been having a hard time finding what I want for the price (preferably $150 - $300 range). I am not a gamer and I mostly use my computer running various software programs (Microsoft world, excel, outlook), running trading platforms and to view the web for research, so I usually have multiple tabs open - basically a lot of multitasking. I currently have a dual monitor setup with 2 20" widescreens and will most likely add a third to my setup.
The problem I mainly have when looking at video cards is the amount of monitors they are able to support and the types of connections they have. I would like to run a minimum of 3 monitors and would like to have the option in the future to upgrade to 4 monitors. I want DVI connections or DP connections that can convert to DVI. Also, If running 3 monitors I would like to be able to make the center monitor have the task bar and be the main monitor. From my research the only video cards that have these capabilities are workstation video cards, more specifically the Nvidia NVS 450. This card even has the ability to extend the task bar along multiple monitors and allows you to stack monitors (i.e. 2 x 2 monitors). However, this card costs upwards of $500-600 and I am not certain but it may only be a 2D card. As I mentioned I don't play games but I am unsure if I will ever need 3D capabilities for anything.
My custom build will include:
i7 2600K
Asus P8Z68 Deluxe
Crossair DDR3 Vengeance 8GB (2 x 4GB) DDR3 1866 (PC3 15000)
Seasonic 850W X series
Corsair - White 600T Mid-Tower Case
80GB SSD and 1TB HHD
With that in mind can anyone throw some suggestions my way for a graphics card that can accomplish what I am looking for? Again, I like the flexibility of the workstation cards and the fact that they can support multiple monitors but I just don't like the price - are there any mainstream cards that have these types of capabilities? From what I read the reason those cards are so expensive is because of the tech support you get with them as they are mainly intended for businesses.
Thanks!
i7 2600K
Asus P8Z68 Deluxe
Thanks!
