Video Card Side Grade Advice
TheBlackAngel
Hello all,
I am looking to redo my PC this holiday season and switch over to the PCI-E platform. I won't have enough money to redo everything and get a high end video card. I currently have a 6800GT. What I am looking for is a video card that is PCI-E, will perform at least on par with my current 6800GT, and cost around $100 (+/- $25-30). Anyone have any suggestions on what I should go with?
For the other parts this is what I am looking to get....
MB
http://www.newegg.com/product/product.asp?item=N82E16813131096
PSU
http://www.newegg.com/product/product.asp?item=N82E16817128002
CPU
http://www.newegg.com/product/product.asp?item=N82E16819103741
RAM
http://www.newegg.com/product/product.asp?item=N82E16820211064
Total with the video card I don't want to exceed $400, those items put me at $286 without shipping.
Then eventually I will add another gig of RAM, and replace the video card with a high end one.
Thanks for the help!
For $100, you can snag a new X1900GT or used 7900GT. Either one will roughly double your 6800GT's performance.
Where can you get a x1900gt for $100. I looked and couldnt find one cheaper than maybe $200.
I have been able to find the 8600gt for $100. And the 7900gs for $99 AR. Both of these options will be nice upgrades for sure.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161016R
You missed a few deals last week.
http://www.hardforum.com/showthread.php?t=1227329&highlight=x1900gt
http://www.hardforum.com/showthread.php?t=1230767&highlight=x1900gt (Refurb, but with warranty)
Yes, another vote for the 1950 PRO. They recommend it HERE at that price range. They at Tom's Hardware do a monthly update on what would be the best card for the money for that particular month, so that would be a good place to check. Also there is THIS chart that shows performance among various games. Is an interactive chart, so you can pick 2 different GPUs and one game, and see how it compares to each other as well as others at the same time.
So yeah, I hope that helps.
Thanks for all the replies! So it looks like my options for more of an upgrade then a side grade would be the x1950 pro, 7900GS, or 8600GT. Just out of curiosity how do you all think a 7600GT would compare to the 6800GT? this is on the cheaper end of the spectrum and just curious how it would do.
Thanks!
Thanks!
Most tests put the 7600 GT about 10-15% faster than 6800 GT, or about on par with the 6800 Ultra. It's a good card (I'm using one), but you don't save that much by choosing it over the much faster 7900 GS, so I wouldn't call it a great value at this particular point in time.
