JSSheridan
- Aug 10, 2014
My HD5870 just bit the dust. The system boots up fine with another card.
I'm looking for a PCIE card that will compliment my CPU without being GPU bound.
My system
Intel i7 860 2.8 GHz, not overclocking.
Gigabyte P55-UD3R motherboard
OCZ 850 W power supply
1680 × 1050 resolution
Windows 7-64 bit
What do you recommend?
TIA
My system
Windows 7-64 bit
TIA
