Video Card questions
dbu8554
I am looking at this card best deal I have seen on an 8800
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125089
I know its not the fastest but I have a 3 GHZ P4 with 1 gig of ram not the fastest system, I also wont be able to afford to build a real system for a LONG time due to being a broke fuck.
My question is, in the pictures section of the video card its got some black box with wires coming out of it and it looks like the same color of wires my HD TV receives from the cable box.
Anyways what do I need to do so I can make this card put whats on my computer screen on my 60 inch HDTV?
Assuming you are looking at 720p on that HDTV, then yes. I think that card will suit you just fine. Those are component video outs from that box, so you are good there. However, make sure your motherboard has PCIe slots and not AGP.
Yeah its got PCIe my last nvidia card was a return to frys it was a 5000 something and the fan took a shit about 2 weeks ago sad thing is it could barley run HL2 :(
Anyways I dont care what quality the signal going to the TV is as long as I can get my computer shit to my TV without issue dont care if its using the normal white red and yellow cables or the HDTV ones just want to watch porn on the big screen.
