Video card question (radion 7200)
DoapFeand
I have a p3 450 and i have 450 ram, i am using a radion 7200, i have the 4.2 catalyst and my os is win98. The video card seems to be lacking in effect, when i try to play trivial games the fps is quite low, in fact too low for a radion 7200. If anyone has any ideas on how to optimize the cards performance or if anyone could tell me the conflicts that might be causing it to run slower it would be much appreciated. I have tried the following, disabled shadowing, took down the ram, defrag, and formatting
thnx in advance
well not only do u have an old graphics card but you also have a slow processor.
myabe u can try to overclock it a bit?
That is true but i can run graphically intense games almost perfect, for instance i can play WC3 and wolfenstien: ET but not other games that require less, so there has to be some sort of conflict that is causing the cards performace to be hindered
Could it be the OS? would Xp be a better route or would that further deterriorate the performance of my already bogged system
If i choose the route of overclocking then what would be the satisfactory amount of mhz to increase it by without having to buy another cooling unit for my system
XP would use WAY too many system resources...and slow it down even more.
450ram????
Xp requires 64 megs of ram, ive seen it run on 64 and its mad wack. however, i have seen pcs with 128 run it just fine with no issues.
Although you cant load it down with apps, you gotta keep it running clean.
yeah i have something like 458 , a 256,128,64, i use a Aopen mobo, i was wondering if xp would be a solution not really an alternative
