Falchion17
- Aug 29, 2010
Ok so I just built my new computer yesterday and had it up and working with no problem. I have a 23.6' LCD monitor and was using HDMI from my motherboard (MSI 880GM-E43 AM3 AMD 880G HDMI Micro ATX AMD Motherboard) for the display with no real problems.
So after I got some stuff installed on my computer I decide to go ahead and install my new Radeon HD 5770 GPU. The directions said to make sure that I disabled any on board graphics from the motherboard but after a quick search through the guidebook I didn't see a way to do that so I decided to continue regardless. Anyways, I turned off my computer, installed the 5770 in my case, and turned on my computer again only to find that my monitor will not work. I tried using the HDMI, DVI , and VGA all with no success because my monitor just says no input. I then took the video card out but still had the same problem where my monitor still dosen't work.
My question is what did I do wrong and how can I fix this and get back to where I was (the monitor working fine).
