Video card Price/Performance ratio
phiquach
Is there a place i can go to see like a list for like price of a vid card and the performance wise? Like i want to buy a vid card but seriously, i don't know the difference between 9600 and x1300, stuff like that. so i want to knwo if there is a list for like top vid cards down to crappy ones.
First off you have 2 different types of card worlds.. AGP vs PCI-Xpress I would say you don't need to see anything to make a choice there the X1300 will out number the 9600 no question..
I think phiquach might have used that as an example. If not, might be best to do some research into the latest types of cards :) Search is your friend :)
PS: GaMbiNo
(22) No active links, graphics, code, profanity or advertising allowed in the SIGNATURE. Sig line is limited to 10 lines total as viewed @ 800 x 600 resolution or no more that 15 words per line.
PS: GaMbiNo
What are you talking about?
this is fairly accurate even though it is THG
http://www.tomshardware.com/2005/12/02/vga_charts_viii/page21.html
all PCI-E, no AGP
when you figure out what card/cards you think you want, find that card's price on Newegg.com, zipzoomfly.com, and monarchcomputer.com, then you can decide for yourself what card will deliver the best performance within your budget
i can tell you a few cards that have high value per dollar, especially if you overclock them
lower performance to higher end in general, but not absolutely:
6600GT
x1800XL
7600GT
7800GT
x1800XT
x1800GTO (to be released)
7900GT
7900GTX (i say this because for $500 this card beats the $650-700 older 7800GTX 512)
all PCI-E, no AGP
6600GT
x1800XL
7600GT
7800GT
x1800XT
7900GT
Of those on the list I could only reccomend the following cards with a max price of. (What I think thier worth)
80$ 6600GT
120$ Radeon X1600
200$ x1800XL
200$ 7600GT
220$ x1800XT
250$ 7800GT (for 50$ more get a 7900GT)
320$ 7900GT
450$ X1900XT (Better filtering quality and still good performance and HDR+AA)
530$ X1900XTX (Same as X1900XT and HDR+AA)
550$ 7900GTX (Less power and Quiter then X1900 cards)
On a side note, I would not reccomend any ATI crossfire cards unless AA+HDR and/or HQ filtering is improtant to you, as a 7900GTX solution is cooler, quiter and takes less power then the X1900 series at a lower cost.
Oh and as to your question Toms VGA charts are good.
http://www.tomshardware.com/site/vgacharts/index.html
Oh and http://www.anandtech.com/video/showdoc.aspx?i=2717 for higher end reviews, the Hardocp review is somewhat helpfull although to skimpy to use as a really good guide.
Only reason I got my X700 was because it was $99 on Black Friday :)
I think midrange has historically been the home of the best price/performance ratio.
80$ 6600GT
120$ Radeon X1600
200$ x1800XL
200$ 7600GT
220$ x1800XT
320$ 7900GT
word! I just ordered a X1900XT upgrading from a 6800NU (agp).. and this is basically the same list I thought after some research
80$ 6600GT
120$ Radeon X1600
200$ x1800XL
200$ 7600GT
220$ x1800XT
320$ 7900GT
you should research your prices, for instance, one of the best 7900gtx, the evga sells for 499 direct from evga
and please, stop using HDR+AA as if its a functional feature, theres all of two games i think that even support it, and the performance hit makes it not worth using from what i can tell, kind of like SM3.0 support on GF6 cards, HDR+AA should be a useable feature when R600 is out, like SM3.0 became less of a burden with G70
Dude, I don't care about HDR+AA or even AA that much, just look at my sig and you would know I don't care about it really.
And also I put those prices as MAX I would pay for those particular cards, based on thier price/performance braket.
