JohnSearle
- Aug 23, 2006
I was looking to build a machine that, for the most part, would be rarely needing graphical power (as in computing power). I would, however, like it to be in a position to make use of power if necessary. The idea being that it would use low wattage normally, but if I want to play the occasional game, it can handle it.
So, I was wondering if anyone can suggest a way to accomplish this.
I could buy a half decent card, and then when I need it pop it in, and when I don't need it, take it out. But that seems like a lot of work, and it would probably wear down the gold pins.
The other thought I had was to underclock it, but I've heard that going to low can damage the card. How low can you normally go?
Does anyone know of any possible solutions?
- John
- John
