Video card needs
AlanT89
Hi, I know this might be a little soon to ask a question like this but here it is anyways. What kind of graphics card do you think I would need to run diablo 3? I'm guessing the game would be a little more graphics intensive then Starcraft 2. So anything that can run SC2 at the highest settings would most likely be able to run diablo 3. I currently have a 500 W power supply. Would I need to upgrade it? or will graphics cards get more efficient?
thanks
What are your system specs? I don't think Diablo3 will be more gpu intensive than SC2 IMO.
What graphics card are you currently running? System specs? I think that your PSU should be handle a GTX 460 or a 6850 without any problems which should handle Diablo 3 w/ out a problem.
