Video card muscle vs resolution?
Valnar
I'm sure a review out there exists, but my google skills are weak this morning.
Is there a review or table somewhere that shows the diminishing returns of the last several generations of video cards in relation to the resolution you run it at? Specifically, if my monitor is only 1680x1050, is there a point where frame rates don't really get any better on X video card if using Y monitor? A cross-selection of benchmarks or popular games would be fine. Almost anything that shows a comparison frame rate between two constants if you change the rez.
Edit:
Such a table would also help me decide if I need to upgrade my video card if I choose a better monitor.
This information is in almost every video card review published this decade. What video card/monitor are you using now?
I think guru3d and anandtech have a video card database comparing at several resolutions.
But I don't think they still have numbers for 1680x1050, only 1080p and up.
What you get to do with a high-power GPU versus a low-resolution monitor is see how far you can crank up the AA settings.
Using Nvidia Inspector, I was able to play Mass Effect 2 on my 1680x1050 monitor and GTX 680 set to 16x CSAA + 4x SGSSAA + FXAA and still get 60FPS+. It finally got unplayable with the ridiculous setting of 2x2 Supersampling AA + 8x Multi-sampling AA + 8x SGSSAA + FXAA - and that still didn't max out the 2GB of VRAM.
You can bring any computer or super computer to it's knees with a few lines of code.
Sliders all the way to the right already? Install an HD texture back, hack it more tessellation or more AA...
Diminishing returns in video games can be a moving target because of people's differing opinions.
Please get a better monitor first thing off. 1080p is still around but everyone has now at the 2560 x 1440/1660 or 4K res now. Some will stick to 1080p or lower no matter what. It is like the xp people that didn't want to move to a new os. Once they had to they was really happy about it. Don't cheat yourself treat yourself.
(O.T.) Why are you doing a copy and paste post in every post you do? All they are going to do is start removing your post and zero out your post count if you keep on doing this. How about actually help and don't do one word post. I know you want to get to 100 post count but do it the correct way.
http://chocobar.cf/13/g.png
this info I also really need ..
Well, at any resolution I prefer 16:10 over 16:9 because it's better for most of my work. All documents self adjust to the resolution anyway, but Windows icons look perfectly sized with my 1680x1050 without needing to change the default text size. I'm quite happy with it.
Going with something 1920x1080 will just make the monitor wider, take up more desk space, and move my speakers farther apart. Now a 1920x1200?....hmm...maybe. ;)
I'm pretty sure the majority of people do not run 1440p/1600p or 4k.
Most do not want to upgrade. Higher resolution isn't for everyone. I need the screen space though. You can always get a high end monitor and dial it back down to 1080 if that tickles you. Then have the option to go up later on as you feel the need. The main reason was the 120/144Hz 1080 panels for gaming. That has now moved over in the 1440 panels now though. 1080 is pretty much the normal now these days. Most laptops now come with 1080 now. Unless it is some budget laptop/netbook.
1440 at 120fps take serious horsepower. I think 1080 will stick around for awhile.
Or some people don't want LCDs... Because even a 21" 1600x1200 CRT has equivalent pixel density to a 32" 2560x1440. There is more to a monitor than just resolution and you don't seem to understand that.
No. On a LCD, you should never, ever set a resolution other than native. And on a 4:3 or 16:10 CRT, you should never use 1920x1080.
You need to stop posting in these forums. You have made the dumbest threads I have ever seen in here asking stupid questions back to back in here. But yet you try to come in here and tell me I don't know anything. I take what you post with your trolling with a grain of salt. Go create another thread that makes no sense as that is what you are good at.
That is because most just want a cheap laptop. They will not be gaming on it. Just surfing on it and taking notes, etc. Hence the reason I said budget laptops and netbooks. People love to go cheap and that is just the way it is.
Considering budget laptops comprise the majority of the market...
Um, why not? :confused:
It doesn't hurt the monitor, and while it won't appear ideal, it can certainly be done.
Again, why not?
I had a CRT 1600x1200 monitor which could run 1280x720 easily, I just adjusted the height/width of the display manually to make it appear properly without stretching.
Just because you don't like 16:9 resolutions/monitors, doesn't mean that they are bad or wrong to use for XYZ application.
That choice is really up to the user to define for themselves. ;)
Not sure who you're referring to, but it matters not since everyone who has responded to you has been correct, so you probably need to calm down and evaluate what you say before you say it, because you've made a number of false statements in this thread.
Again, why not?
On a CRT, why would you want black bars? On a LCD, why would you want scaling blur? You should always use the native resolution on LCDs or a resolution in the appropriate aspect ration on CRTs.
Actually very few people I know have 1440+. 1080P seems to be the nor sadly still IMO. Mobile phone resolutions will go 4k in our pocket before PC monitors catch up.
Can you not see the quotes? And what have I been proven wrong on numerous times here? And what false information are you taking about? You mean if you cannot afford anything over 1080P I'm wrong? This is [H] not a Toys-R-Us pc forum. Like I said most will stick with 1080 as that is what they can afford. Or don't have the gpu horse power to push anything more.
It is simple you can either run 2560 x 1440/1600 or 4k and afford it or you can't. Plus I didn't say anything was wrong with 1080P monitors. I mentioned for him to upgrade to 1080p. As it is the normal these days. Example minimum monitors they run. I don't care what you run or anything for that matter. If you are happy with 1080 then that is all that matters. Some of us need more screen to do other jobs on the pc. But everyone is using their opinions here to begin with.
I would love to see a mobile phone push 4k. When we can barely do it with 2 high end gpus.
You quote upside down as opposed to everyone else on this forum. If someone is not aware of this, it looks like you might be responding to the OP with your first answer. It took further posts by you in this thread for me to remember that you are are the guy that inspired my sig.
The way I quote has nothing to do with you helping out in this forum. No one here or any place for that matter sets a rule on how to quote other people. It doesn't matter if it is top, bottom or sideways. You have enough brain to actually think and put them together. You can easily figure out what someone is saying that doesn't speak English. But you are telling me you can't understand if the quote is or after the reply, who I'm talking to? Try thinking outside the box for once and stop following everyone else in the world.
But then again you cannot please everyone, right? So by your thinking, anyone that does something different is now labeled wrong. And then you make a signature about it in your thread. Talk about being biased.
If people wasn't different or thought different. We wouldn't have food choices, different vehicles, different styles of clothes. You see where I'm going with this. I highly value you people that think different and stand up for their own beliefs and decisions. The ones I fear is the ones that follow something because another person said it was correct.
is it really that hard for you to figure out who he is quoting?
You probably don't follow the mobile phone scene. The next generation soc's will support and offer 4k resolutions. Do some research.
Lets keep the topic about video related thingys and not how someone posts on the forum.......any further personal insults will result in infractions being handed out
