comikehill2002
- Jan 27, 2005
http://www2.newegg.com/product/product.asp?item=N82E16814122208
Will this video card push a 26 inch LCD TV/moniter?
Only thing Im doing is building one hell of a tower to go with that big bitch....lol. I have about a 2300 dollar limit on it.
That budget probably includes the huge lcd, which will eat away about half of it.GlimmerMan said:Then why are you looking at a 6600GT? Go for SLI. I build my BFG 6800GT SLI rig for about $2100 back in Jan. So you should be able to build it for cheaper now. Look in my profile for the parts.
workingnonstop said:That budget probably includes the huge lcd, which will eat away about half of it.
GlimmerMan said:You can get cheaper memory, replace the raptor, use on-board audio, and get a case that includes a 500W PSU. This will knock off over $200.
If you want to go single card, I suggest 6800 GT or even 6800 Ultra since money does not seem to be a big issue. You will be driving a hugh screen, so don't go cheap on the video setup.
When did i say anything about a raptor
GlimmerMan said:You said your budget was $2300. So I responded that you should be able to afford a much better video setup and pointed to my setup that cost $2100. Then I suggested ways to reduce the cost if it was too much. Was only trying to help. Didn't mean anything else.
GlimmerMan said:No problem.
If you getting a TV tuner and hooking it up to a hugh TV, why not consider Windows XP Media Center 2005?
nomar said:What 26" LCD is this? Don't think that just because it is bigger and HD compatible it will have high resolution. It may only be WXGA - 1280x768.
