Video card keeps coming loose
supyo
Second time in a month my 7850 has come loose. At first there will be minor corruption and then the card won't initialize. I reseat it and it works fine.
It seems secure in the mobo and I have it secured with both screws.
The only thing different I can think of is its been pouring rain all month and then got really hot so the humidity went crazy.
Could it be the humidity? System is working great other than the gpu coming loose.
what is your mobo? does it have the pci-e 3.0 slot yet? or not?
Its an ASRock B75M-DGS. 7850 is seated in a pci-e 3.0 slot.
CPU Type QuadCore Intel Core i7-3770, 3700 MHz (37 x 100)
Motherboard Name ASRock B75M-DGS (1 PCI-E x1, 1 PCI-E x16, 2 DDR3 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset Intel Panther Point B75, Intel Ivy Bridge
System Memory 16328 MB (DDR3-1600 DDR3 SDRAM)
DIMM1: SuperTalent SUPERTALENT02 8 GB DDR3-1600 DDR3 SDRAM
DIMM3: SuperTalent SUPERTALENT02 8 GB DDR3-1600 DDR3 SDRAM
BIOS Type AMI (12/20/2013)
Display
Video Adapter AMD Radeon HD 7800 Series (2 GB)
Bus Type PCI Express 3.0 x16 @ 1.1 x16
it has no reason of coming loose unless your not latching the clip at the end of the pci slot correctly when seating the card in the slot
due to the latch that holds the card in...i seriously doubt thats the problem.....i have moved my pc a hundred times and never had an issue like that....its got to be an issue with either the motherboard or the card...something aint right
It's not actually visibly loose, but simply seems to start working again after reseating, right?
If the ambient temperature has increased significantly then I would suspect the motherboard may be warping a slightly.
I had a similar issue once. Question: Does the card actually slide out of the slot abit? or does it just quit working and you have to take the card out and put it back in?
Once before I had an Asrock board was a 770 Extreme3, I thought the card kept slipping out, but was was actually happening was the PCI-E slot was actually loose, it eventually fell of completely and I RMA'd. If you haven't already I would check the slot itself. If that happens to be your issue, then maybe Asrock boards are just crap, (I believe they are.) lol because that board I was just talking about, I had to RMA that thing 3 times, then after I got the 3rd one and I sold it before I even opened it, my buddy that bought hasn't reported any issues with it.
Good Luck.
Stay [H]
