video card issues
I just installed a BFG 6600 GT OC. I shut down & restarted my PC. I hear two weird beeps. Then nothing appears on the monitor. Any solutions?
Check over things, and make sure that the card is inserted in the slot all the way. For that matter, check all of your cards.
Make sure your memory is seated properly, and that no cables are unplugged.
Did you uninstall the drivers for your previous graphics card? Will the machine post?
Check your USB headers on the mobo... make sure you have the connectors on the right pins (assuming they're not one piece connectors).
Other than that, try to give me as much info about your system as you can, otherwise all I can tell you is generic stuff.
-Caleb
