Video card help
Scootel2
I just purchased a 7770 and think I need something with more power. I want to game at 1920x1080 with all settings maxed out. Suggestions?
What case, PSU, and CPU do you have?
What's your max budget for this upgrade?
Which games are you playing and planning on playing?
Case is Cooler Master RC-120A-KKN1
PSU is Corsair TX750W
CPU is Core i5-2400
I have no budget but I will not pay $1000 for a video card lol :)
I play Starcraft 2, Diablo 3, Arma 3, I may get SimCity.
Thanks for the help
If I have to change case I will :)
The 7870XT is best bang for the buck. If you sell the games it would cost you about $150. You're not going to get maxed out with Tomb Raider or Crisis 3, but there's not much point in going higher end with an i5-2400.
My CPU will bottleneck me? It will have to get replaced then :)
