Video Card Help..
Nyvo
I have 3 Dell U2410 Monitors i plan to run in 1920 x 1200.. with eyeinfinity or vision surround depending on what card i get of course.. I game with this system.. FPS and quick load times are important to me..
I've been looking at loads of cards.. and it comes down to these 4.. any advice here would be welcome
Radeon 6990 so is this one just dual 6950's on a single card?
GTX 590 i've read this is just two 570's on a single card.. so anyone know for sure if this card dosnt perform as well or better then dual 580's?
Radeon 6970 would i be better off running two of these in sli?
GTX 580 or should i do two of these in sli?
Is your mobo crossfire/SLI compatible? Whats your budget? Whats your PSU? From a straight cost/perf Point of view, I would suggest 6950/6970 crossfire. If you can't run crossfire, 6990. 590 is overpriced compared to the 6990 as well as being VRAM limited at the resolution you're running, as would be the 580.
my budget is 4k and thats not including the monitors i just bought.. i'm building a whole new system which is why i didnt list my parts just yet
