Take the title as is, seriously.
Computer specs:
PNY GeForce GTX 260 Core 216
Intel Core 2 Duo E7400 (OC'd to 3.0)
2GB Corsair ValueRam (1GBx2)
eVGA nForce 610i Motherboard
Antec 500W PSU (Semi-Old)
OS:
Windows 7 Home Premium
Ubuntu 9.10
The Run Down:
My video card's fan (GeForce GTX 260 Core 216 by PNY) is making a grinding noise -- and not the typical fan noise either, this sounds as if its a construction yard or a train going down some tracks. Yes, I did clean it.
Text of wall fans:
About a month ago, my computer's CPU heatsink failed to work as its suppose to. So I upgraded to a thermaltake one. Now, the reason why I mention this, I have a Mid-tower case, so the CPU HS and fan takes up a whole lot. That's fine with me.
Now, three days ago, I heard a loud annoying grinding noise coming from my computer. So, out of a panic, I turned off the computer. Fearing it was the CPU fan. I waited a second, then restarted. No sound untill about four hours later -- when I was playing Half-Life 2.
So, again, restarded. Sound went away, and I got into contact with my computer-wizzy friend, who said it sounds like the a fan is hitting something. Yesterday morning, it did the same thing. I got on my knees, removed the case cover and listened in. It sounded as if its either coming from the new heatsink or my video card. I can't tell. Just to see if it's not from the CPU HS, I took the CPU fan controller and speed up the fan, and slowed it down. The grinding noise didn't make any difference, it was the same. Even though I can hear the fan it self humming louder. That's normal.
Restarted the computer, sound is still there. Turned it off, removed the video card, no sound. I went ahead and grabbed a screwdriver or two and removed the HS cover from the video card, and proceeded onto cleaning it. Afterward, reassembled and smacked it back into the computer, and it's still making the same sound.
Any ideas what it is? Any idea how I can fix it?
Computer specs:
OS:
Ubuntu 9.10
The Run Down:
Text of wall fans:
