Video Card Fan
brh48
I just bought a used GeForce ti200 and the fan doesn't work. I have a new power supply, also. Is the fan just plain shot, or can it be replaced?
I have a visiontek ti200 that overclocks to ti500, send me $50 & you can have the card, fan, ramsinks and all! :)
or you could just pick up a replacement fan from compusa or online for cheap.
the fan can be replaced, but if you want to ghetto rig it, slap an 80mm fan to blow over the card.
chech the hot deals forum, newegg has 10 80mm fans for 10$ shipped.
I had a Visiontek Ti-500 that had the same problem...I put a Crystal Orb on it, and it was good as new. Fans are easy to replace and there are many to chose from, check out NewEgg for starters.
Thanks for the info. I'll check out Newegg first and then think about buying that card for $50.
