Video Card Fan Connector
Hawkeye
I just bought the Arctic Silencer 2 for my 9600 XT. The power connector for the fan though will not in any way come close to fitting on my Asus 9600XT. Right now it's running with just the heatsink which hopefully will not ruin the card. I periodically check it to make sure it's not getting hot. However, the PCI slot for heat exaust so far seems to be adequete for letting the heat diffuse from the heatsink out of the PCI slot. Anyways, I have a Dell motherboard and i was wondering where I can find some sort of power converter/connector so that I can attach the cooling unit's fan. So far all the power connector converters for fans have been regular PC fans and those pins are much too large for the very small video card fan connector.
dude R U CRAZY?!?! your slowly killing your vid card!
get rid of the power connector and hook it up directly to the
molex, generally there are 3 cables, +12(usually red), ground(black)
and Fan Pulse. MAKE YOUR FAN WORK!!!!!!
so the fan power connector wont fit, wether it´s the length or it´s too big for your on-card power source doesnt matter now, just carefully remove the three cable from the little molex (the plastic housing that connects to the power source) or cut them off, now with a wire stripper remove 1cm (aprox 1/2") of the insulation, and connect the cables (red +12v and black Ground) to your PSU molex, u know like the connectors u use on your CDROM, on these PSU "molex" ,with 4 cables, the 12+ is the yellow cable and its Ground is the black cable next to it, the other cables is the red 5+v and its ground.
Hook your fan to the 12+v and its ground and then put some insulation tape around it
be carefull to identify the fan cables properly, usually the "FAN PULSE" cable is yellow.
Wow thanks. I've never done anything like that before and I'm surprised it worked.
