themorningbells
- Mar 8, 2004
So I built this computer about 5 months ago. Running a E5200 on a GA-EP45-DS3L with a Sapphire 4850. PSU is a Corsair CMPSU-620HX, RAM is G.Skill Pi 4gb kit. Running Windows XP. All was working well until about two days ago when my problem started. I'd just be at the desktop and all of a sudden my monitor would flicker in an out (both of them, I'm running dual displays) and my computer would freeze (well, get really choppy like it was trying to work something out and then freeze). Also, one (random) of the monitors will just go black and I have to go into my video control panel and re-enable one. This would sometimes work if the mess didn't cause my computer to freeze that particular time. Things will work sometimes for maybe a couple hours then it'll start doing this. Or it'll work for about 30 seconds and do it. Also, when a monitor blacks out for a second then turns back on (by itself), I'll get the windows has detected new hardware sound. I had it just setup to one monitor last night and was watching a movie and after about 20 minutes it started to flicker, then it would go black, half a second later the detect new hardware sound, it would turn back on, and it would repeat this rapid fire until I turned off my computer. I've never had a problem like this before so I'm turning to you [H] to help me diagnose it. I can only assume my video card is the culprit. I opened up an RMA and I plan to send it back, but I was wondering what you guys thought before I do so. Also, I tried updating drivers and it did the same thing. /shrug
