[+Duracell-]
- Jun 8, 2004
So I just installed a new HD4850 in my system, and I was running Oblivion when all of a sudden my screen turned black with blue squares in a weird pattern. I promptly turned it off and let it sit for a bit, thinking the temps were a bit high.
I get back into windows, and sure enough, they were getting high. I found a thread where you can adjust your fan speed in a CCC profile, so I did that. Ran a few things to stress the card and I got screen corruption and freezing when sensor #2 (according to GPU-Z) got around 100C.
I let it sit for longer. I installed a fan up front, thinking more airflow might help. I have an Antec P180 with only one fan in the rear sucking out, and it's worked fine for my previous config. Turned it on again. When I got what was supposed to be the Vista login screen, all I got was a garbled screen of pixels and colors.
I have my old card in here now, and the HD4850 is sitting out in an anti-static bag cooling off. It's quite possible that it didn't get a chance to cool down after the second time because it was still quite hot when I took it out. I'm going to try again in a bit, but what are the possibilities that could have happened? I swear my old card (X1900GT) has ran at much higher temps and nothing has happened to it.
