Feb 2, 2004 #1 K Kami Limp Gawd Joined Feb 1, 2004 Messages 180 So far I've seen some nice results in OCing the core of a Radeon with a VGA silencer, and I was wondering which would give me better cooling, the VGA Silencer, or the Zalman ZM80C, with the Zalman fan. Any other recommendations are welcomed.
Feb 3, 2004 #2 K Kami Limp Gawd Joined Feb 1, 2004 Messages 180 Bump Anyone know how to take the fan off of a Sapphire 9800pro lite card? It has plastic things aren't really screws...
Feb 4, 2004 #3 K Kami Limp Gawd Joined Feb 1, 2004 Messages 180 Last attempt at reviving this thread. Could someone recommend RAM heatsinks for the 9800pro to me?
Feb 4, 2004 #4 CompMage Gawd Joined Sep 7, 2003 Messages 851 Ok in order. a) I would take the Zelmen if you must. I use the Vantec ICEberg 4 with Artic Silver 5 on it. b) Remove the basic clips with nedle nose pliers. Squese and push the pins threw after unclamping the clip. c) You do not need ram sinks. I will not give you any more stability or long gevity for you video card.
