Video card confusion
Only suggestion I'll offer is to remove the X1600pos from your list.
It's a horrible card.
The X800GTO is better, because it has faster DDR3 memory and a 256-bit memory bus, compared to the X1650's DDR2 memory and 128-bit bus. They have the same number of pipelines, but the only disadvantage of getting the X800GTO that I see is that it can't do AA and HDR at the same time, which the X1650 is able to do.
I may be wrong but i dont think the x800 supports SM3.0 either otherwise its the fastest of those listed.
You're right but SM3.0 isn't used by too many games and there's not much difference in image quality either, the only small advantage being from a performance viewpoint.
And don't overlook that the X800GTO is open box, you get the card ONLY, no cables as in the pictures.
And...
* Return for refund within: 15 days
* Return for replacement within: non-replaceable
Im about to order the X1650 but the only thing Im worried about is the power cable. Im not too positive if I have the connection for that(pretty sure I do, just wondering). What can I do to make sure? Im not currently using a floppy drive and I know the card and those drives use the same plug.
