Video card bandwidth usage at "idle" ?
Valnar
Does anyone have an idea of how much PCI or PCI-E bandwidth is used with a video card that is sitting idle running Windows? If I have a server, and throw a PCI video card in there, how much bandwidth does that take from the PCI bus' 132MB total bandwidth? It's just going to sit there at 1024x768 32bit in Windows, not doing anything.
Or if I buy a new G965 motherboard, the integrated Intel x3000 graphics shares the bandwidth with the PCIe x16 slot. I know that's a massive amount of beau coup bandwidth, but if I want to use a RAID card in the single x16 slot, I want to make sure there isn't some "lowest common denominator" problem that will have the graphics drag down my PCIe x16 bandwidth for that RAID card.
Sorry I couldn't be more clear.
Robert
Well, here is an oversimplified idea of how much it will be using:
1024 * 768 * 32 = 25165824 bits per second or approximately 3MB per second. You are never going to notice the bandwidth usage.
If you have a standalone graphics card, and the card is sitting there doing nothing, it uses practically zero bandwidth.
The card is passive - nothing changes in the framebuffer unless some program or the OS makes it so. The framebuffer is entirely isolated from the rest of your system, so there is no overhead writing that data out to the screen.
Onboard graphics does feature some overhead because the framebuffer uses main memory, and this framebuffer must be written out at whatever refresh rate and resolution you're running (that's mentioned in the post above). This won't impact your PCI / PCIe bus bandwidth, but it will impact your main memory bandwidth.
As for PCIe, every PCIe link is dedicated - if you have a PCIe 16x slot, it is totally dedicated to that slot only. You do not have to worry about sharing that with the onboard graphics.
