Video Capture/Editing Build advice
Sungaisu
I have a video capturing device from Pinnacle and would like to start putting it to use.
I still have my Antec NSK2480 case laying around so I would like to put it to use if no one ends up buying it. So this will be the case of my build.
I don't have a set budget for this just yet, but I do not want to spend tons on it, as I'm trying to put some extra cash aside to complete my gaming PC. The capture device works through USB.
The Questions.
Video Capture/Editing.
Open ended, preferably under $600ish but I only need a few parts as I have extras laying around, Tax/Shipping included.
3) Where do you live?
California.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, RAM, Mobo, DVD-RW, Maybe a HDD.
Case/PSU, I also have a Coolermaster RC690 laying around if I need to go bigger. WD Green 7200RPM 1TB, WD Black 7200RPM 500GB, Mouse/Keyboard, PCI-E EVGA 8600GT 256mb can be used as a Temp card.
6) Will you be overclocking?
If the Proc isn't acceptable at stock speeds, yes.
22" Asus, or 32" Toshiba HDTV LCD.
As soon as I have the parts planned.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
USB 2.0 (I doubt this capture device could utilize 3.0), I like having eSata as an option.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Windows 7 standing by.
The stuff I've been looking at:
Motherboard: GIGABYTE GA-MA785GMT $89
Proc: AMD Athlon II X3 435 Rana 2.9GHz $75
RAM: OCZ Gold Edition 4GB (2 x 2GB) DDR3 $85
DVD Drive: ASUS DRW-24B1ST $25
Total: $305.20 after Tax + S/H.
I was looking at a XFX HD-4850 1GB but would I need a big video card for simple editing and capture?
Thoughts? Suggestions? Questions?
That's quite a deal on the 630. I don't venture to Amazon often so I forget that it's also an option.
You're building a whole new system just to capture video? What's your current system? :p
Anyhow, g's suggestions look good. If you're near a Microcenter, you can pickup the Ph2 550BE and 785G Asus mATX board for $140. If you're near a Fry's, the Ph2 550BE is only $70. ;) Most Ph2 X2 chips will unlock if the manufacture date is pretty recent -- all you need is a board with SB710 or SB750.
I've never unlocked a BE before, but I hear it's pretty easy. I'm not near a Microcenter, but I'm somewhat close to a Fry's (About 45min). I want a new system because I'd like to keep it next to the TV, and don't want to switch back and forth tasks for it, it may be converted to a HTPC sometime in the future.
+1 on the PII X2 550
building 2 rigs with that chip for buget minded friends.
you just need a MOBO with ACC, either the 785 or 790 chipset, do not go anything else :)
for video capture, you dont need a 4850 but it might be worth it to get the the new 5k series, the 5570 or 5670 might be worth looking at for a simlar price, and 3x monitors and HDMI and whatnot.
The 770T w/ SB710 will work fine, too, for unlocking, but these are typically ATX size instead of micro.
