Video Capture Card that interfaces with MSN; suggestions.
Akagi1982
Hi, I am using an old camcorder as a high quality web cam. I use a video capture card in order for it to interface with MSN and Yahoo.
Unfortuantly, MSN seems to hate all 3 of the cards I tried. an MSN TVanywhere, AIW radeon, AIW rageII+dvd. It doesn't detect properly with the ATI cards and with the MSN card, there is a 30 second delay.
I was wondering if any of you have had luck with a particular card. The lower cost, the better.
The allinwonders usually use some sort of proprietary chip, so it may be hard to get it to work with other software. A BT878-based card would probably work just fine, and they are usually pretty cheap. Look in to the hauppauge wintv cards.
