Video Capture Card Reccomendation?
jmastic
Hi everyone. I just bought a new PC with XP Media Center Edition pre-installed. I'd like to get a good video capture card that would work with a program such as GB-PVR or MediaPortal, since I'd like to take MCE off and install XP Pro. If anyone has any suggestions for a good card around $100 and if there is anyone with experience with either of the two programs listed before, I'd appreciate everyone's opinion. Thanks!
hauppage pvr150mce. works with xp and the progs you mentioned. goes for around $50 at pcalchemy. good picture. pretty much the standard tuner. can get it with fm tuner for $65, and can get it with 2 tv tuners(pvr500) for recording 2 sources at once for arounf $130.
based on some of the newest hardware and reputable reviews, here are the top 3 tuners, in order of preference...
Nvidia Dual View dual tuner card $169 from nvidia.com store -
The nvidia card is new but has 2 tuners and is supposed to have better image quality with smaller file sizes.
ATI 550pro based card, around $80 from pcalchemy.com -
only available in single tuner form as far as I know, but many say image quality is slightly better than the pvr150. Also fairly new.
Hauppauge PVR 150, $65 plus shipping from pcalchemy.com -
The standard that all others are judged by. this doesn't mean it's the best, just the standard. Widely supported card with good image quality, especially if the source is clean. A dual tuner version (PVR 500 is available for about $130)
MCE is XP Pro, all you have to do is disable (in the services) the MCE app.
