PCFIXERUPPERGUY
- Jun 12, 2004
Please help me! OK I have had a Tt Giant III on my 5950 Ultra for quite a few months and just yesterday I got some ramsinks to put on that sucker so I could OC like crazy. Anyways after installing the ramsinks and cleaning up some AS5 goo that got spread around accidentaly I reinstalled the card and proceeded to boot up. When I booted up I got some error about memory not being able to be read and after I clicked OK my computer went into a freeze with a beep from the tower speaker which would last about 10 seconds and then come back for about 5 seconds and then over and over so I rebooted again. Right before I installed the card I had AS5 on my hands and although I did remember to clean and search the card for AS5 traces I forgot that I saw some on the AGP port where the gold connectors are and installed it with AS5 still on it. I just remembered this when I started KOTOR and saw little red and blue specks on the screen and was like "WTF?" so I uninstalled the card and saw that there was still the AS5 that I saw on the slot so I cleaned it off with an alcohol dipped q-tip and I also tried to clean the inside of the slot on the motherboard too but I couldnt find anything to fit in there to do so. My problem is even though I cleaned off all of the AS5 in the important areas (except the MOBO) I am getting these artifacts all over the place and am having a few lock ups here and there. Could my problem be that there is still some AS5 stuck in the mobo AGP slot or does it have to do something with the ramsinks? The ramsinks I used are the ones that are advertised with the Tt Giant III of which I bought 8 extra so I figure that is far from the problem. I seriously think its the AS5 stuck in the AGP slot but I cant think of a way to clean it out. Is it possible to remove the plastic cover and clean it out without removing the mobo? Please help me because I dont want to have to spend my next pay check on a 6800 Ultra just yet. Oh and I let the alcohol dry and whatever before I installed the Video card and turned the PC on. I am very careful with my stuff so I figure that I already know what my problem is I just cant find a way to fix it. Im scared because I really love my mobo and I expected to get far with my memory overclock after installing these things but when I try to OC at speeds even under what its currently at it says that my settings are too high and to lower them so I think something is wrong in the AGP slot. Thanks!
