Vid Card recommendation
JLGatsby
Can anyone recommend a QUALITY video card for my second monitor?
I want duel DVI links. On my ATI X600, I only have one DVI link. The image quality of DVI is very noticable and I want to two monitors to look the same.
According to CPUZ my motherboard is a Dell Intel i945P/G, southbridge is 82801GB (ICH7), and graphical interface is PCI-Express.
I don't need a lot of power, I don't play games, BUT I WANT GREAT BUILD QUALITY. I've heard of cheap duel DVI vid cards flickering when in dual DVI mode.
Recommendations?
U game or no???
If not, an Nv 7800GT or ATIx850PE would do fine running duals. If you game, thats where it could get expensive. I recommend X1800, X1900 or Nv 7900GTX or 7950..... This is without knowing your prefrences, price, or expectations.
solobaricsrock said:
U game or no???
<napoleon dynamite> *deep breath* </napoleon dynamite>
Well if he doesnt game, im sure he doesnt need an expensive card. I would go to newegg.com and look at all the dual DVI card they have. I would recommend cards made by ASUS for build quality. Also, it would probably help a lot if you looked at all the reviews. Maybe sort all dual DVI cards by review.
Thanks
MH
There we go. Thanks for the reply. I was just wondering what brnad or specific card that would offer good quality. Don't need sheer power, just quality build.
<napoleon dynamyte> YEAH GOSH </napoleon dynamite>
You ask me if I game, when in my message I said I don't.
You offer me a nvidia card when I said I have an Dell ATI motherboard.
Then lambasted me for not giving enough info, even thought it was all in the OP.
Yeah gosh.
"I don't need a lot of power, I don't play games, BUT I WANT GREAT BUILD QUALITY."
Maybe that should have tipped em off.. 8)
Yeah gosh.
"According to CPUZ my motherboard is a Dell Intel i945P/G, southbridge is 82801GB (ICH7), and graphical interface is PCI-Express."
This motherboard should work with either NVIDIA or ATI video cards. Both PCI-Express or PCI cards should work fine. I'd go with NVIDIA because of the drivers. BFG and EVGA offer good warranties on their products.
Good luck
I agree with the eVGA and BFG suggestions, but would also add in XFX. If i am not mistaken they have a double lifetime warranty, or something of the sorts. Correct me if i am wrong.
MH
