Vid card prob...
biglip
Ok so i just purchased this Nvidia GeForce 7900 GS KO and like im pretty angry because i found ot my psu is like not powerful enough as the card requirements want it to be. It says on the box that it needs a 400w psu or more, and unfortunately my psu is only 300w... is there anything that i might be able to do or will this card work.
comp specs:
intel core 2 duo (2ghz per core)
1gig of RAM DDR2
250 gig Hard drive
300w psu
if u could help let me know as soon as possible thx!
It'll probably work, but that psu is going to cause stability issues.
I would strongly recommend getting a better psu asap.
comp specs:
1gig of RAM DDR2
250 gig Hard drive
300w psu
it won't matter too much. you sound like you've got a system that doesn't require as much power, that 7900GS won't eat up too much power, although it will depend on the quality and stability of the power supply.
