vajpayee1947
- Dec 10, 2005
Here are the specs:
Athlon 64 3000+
Asus A8V Mobo
Thermalright SI-120 Heatsink
GeForce4 Ti4200
180GB Western Digital HD
120GB Maxtor HD
DVD RW
DVD
450 Watt PSU
I just upgraded to a Radeon 9800 Pro, and have been having some issues. At first, the computer would shut itself down and the screen would flash 'VGA Mode Not Support'. I tried to up the refresh rate in dxdiag.exe but that didn't do the trick. Now, the system shuts down, but it doesn't say 'VGA Mode Not Support'. I stuck my Ti4200 back into my box and everything is fine. So, my guess is either bottlenecking is happening, my lcd is old and the refresh rate isn't fast enough for the 9800 pro, not enough power, or my vid card is overheating.
**Purchased and installed a Zalman vid card dual heatpipe cooling heatsink. When the comp started rebooting, I thought it was best to remove the heatsink, reinstall hte stock heatsink and fan, and wait for the zalman zm-op1 fan to come in.
Any help would be good. I'm pretty much stuck. Thanks.
Athlon 64 3000+
Asus A8V Mobo
GeForce4 Ti4200
120GB Maxtor HD
DVD RW
DVD
450 Watt PSU
