Vid Card for my kid
Fat Elvis
I bought my 10 year old KotOR, and his Comcrap won't run it with its "video chip". I don't want to sink money in this box, but I need a card with DX9 that won't screw up xmas. I don't care on how it performs ( its for a kid remember) what about fx5200 or ATI 9200?
Thanks
Fat Elvis
I played KOTOR on my machine when I had a 5600 Ultra and it wasn't the best experience. Out of those cards you have listed the 5200 is DX9 but the 9200 is only DX8. You might be better off getting him a Xbox and KOTOR on it.
If that isn't an option and you are choosing between the two you listed I would say a 5200 with 128bit memory.
I would suggest a Geforce4 ti4200 - ti4600 off ebay. It isn't DX9, but KOTOR really isn't either. You can get them for about $50 used I believe.
9200 Radeon doesnt support DX9.0, only 8.1 . FX5200 does support it, and I think its better in perfomance then 9200. Though you might think about getting a rR9600. I dont think it such a biiiig difference in money.
I played Kotor on a Geforce 3 and then finsihed it on a geforce 4 4600.
grab a TI 4600 off ebay and he will be able to run anything made up to this point to some degree, and will even play Kotor 2 in feb iam sure.
I have a 5 year old and a 10 year old, they actually play more games than I do so I put a 9500pro in my 5 year olds and a 9700pro in my 10 year olds. They are both happy.
I'd say a geforce 4 or so
I played through KOTOR on a geforce 3, so that should be fine.
Can pick up a new 9600NP pretty cheaply (I think $80ish) and it ran KOTOR just fine on my rig (XP1500+)
The heads up on the ti4600 was great, I checked out Ebay and the price was right, but how long will this card function with more and more games going to DX9. I look at the 9600np but most in my price range ( I'm cheap with the Kids) were LE's I believe you guys gagged on those puppies.
Fat Elvis
Fat Elvis
Honestly, I think you'd be surprised how long it will hold on.
Keep in mind that MOST (like, 70%) of the 'gaming public' is using GF4MX cards which are DX7. Heck, even Half-Life 2 - the most graphically intensive game to date - has a DX7 render path.
Game devs aren't going to be making games that *require* DX9 and WILL NOT RUN on DX8 cards for many years yet. And the Ti4600 was a beast of a card. In DX7 and 8 apps with no FSAA or Aniso, it still outperforms even GeForce FX 5700s. And while the 5700 may be able to do better special effects in games thanks to its DX9-ness, the Ti4600 will be running the DX7/8 path as fast or faster...which has a certain quality all its own.
I played KotOR on a 32 meg GF2 MX 400!... But still I would have prefered SLi Ultras.
6800GTOwned said:
Kids are more perceptive than you might think...
I'd go with SLi Ultras...
I agree.
Don't be cheap Fat Elvies, get a FX-55 Processor and dual 6800 Ultra Extremes in SLI or a 3.4 Ghz P4 Extreme Edition with a large front bus, and a x800 XT PE, with vapor cooling so you can overclock it to 4 Ghz.
Happy XmAs. ;)
I use a 9600NP, the memory overclocks fairly well (almost to pro speed), the core not so great. (only 20mhz)
I bought it the begining of this year and don't intend to really upgrade for awhile yet, it runs everything great. Second to the GF2MX I bought way back in the day, it's the best bang for the buck i've gotten.
You could also try something like a 9550.
It will also depend on the processor in the system. The faster the processor, the more slack it can pickup from the video.
May also want to double check the board has an AGP slot.
Okay guys while I personelly have a P4 3.2 with a X800, my 10 year old is not gonna get a box like this for xmas, its all I can do to buy games a season old to afford them. The MB does has a AGP slot so it makes sense I can throw in a card. Again are those 9600le's are worth it? It looks like I can get a new ti4600 for 70ish or a used 9500pro for that or alittle more. I don't like to buy used computer parts unless I know how they were used and abused whats your take?
Fat Elvis
Woa, 9500Pro for a little more than 70bux? G0000d deal, imo! If it works fine, take eet. 9500Pro overruns 9600Pro and 9600XT even.
They were joking. At least I think/hope they were. Anyway the Ti4x00 solution is awesome. I loved my Ti4600, and now you can get them very cheaply off the used forums or ebay.
Good luck!
