Vid Card Fan Speed
Nismo
I have an FX5900. -Don't play many games... It has 3 speeds. Crazy fast, Fast (gaming) and normal(windows).
Since Vista, the fan stays at Fast speed(gaming) because of the Aero graphics. Is there a way to control the speed of the fan with software or Hardware? It's a little on the loud side right now...
The thing is, the fan is speeding up because the card is getting warmer. If you force the fan to run slower in 3D mode you run the risk of shortening the life of your card.
I would get a VF700 or VF900 if you really want to quiet that card down...just make sure whatever one you pick will actualy fit your card.
Edit: or since you don't play many games, pick up a Passive GeForce 6200
