UnseenClass
- Dec 14, 2002
I've look around, and all the fan silencers, you know the rubber/silicon things you put between the case and the fan are all so expensive. what are some alternatives you guys have used?
I thought about putting little pieces of cardboard between the fan and the case, that would work i'm sure.
