Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'd just say use care if you're planning on using Window 7. The chip has some complains from users, because there is not yet a native Windows 7 driver. It probably works fine if you're not using multi-channel sound.
Also, according to the user feedback on Newegg, you shouldn't buy the board if you are considering using a new C3 revision Phenom II, as the board will not boot.
