VIA pf box
justin82
Hey, can you all tell me which via systems have dual lan cards. Please only list the newer models that have fairly strong chips on em.
The EPIA PD 10000 LVDS has two lan cards and a 1ghz cpu. Should be what you are looking for.
the TC epia's have dual lan as well. not sure about the performance of the cpu across generations though.
C7 > C3 Nehamiah > *
That's all you pretty much need to know
