VIA KT600 Chipset vs. Nforce2 Chipset
Lyquist
Can someone tell me the difference between these two chipsets? I want to know which one is better. Thanks in advance.
Lyquist
one is made by VIA, and one is made by Nvidia... thast pretty much the only documented difference, although i think the kt600 only goes up to 333fsb while the kt800 does 400.. nforce2 does 400.
anyhow, ive dealt with both, and ill admit now that i am biased agaisnt VIA becuase in my experience they make substandard chipsets that are filled with bugs, but the Nforce felt quicker, just a snappier system than the ones that had the kt600. id go witht he nforce myself, since ive never had any problems with it, but thats just me
I own a nForce 2 Ultra board, and I love it. I don't have any experience with VIA's newer chipsets though, but I'd reccomend nForce 2 in a heartbeat to anyone looking for a Socket A mobo.
I'm thinking about getting the DFI Lanparty Ultra B. Does anyone have experience with this board?
Lyquist
KT600 does 400MHz FSB, KT880 adds Dual-Channel RAM support (among other things).
I still prefer nForce2-based solutions, and I've heard good things about DFi's nForce2-based boards.
I had KT333 and a Nforce2 board with my socket A 2500.....I have to say that HANDS down the Nforce2 wins.
I even tried out a newer Via chipset for my A64 and still found them to be buggy as hell. I swapped it out for a Neo2 Platinum and LOVE it. I should of bought the Nf3 board first, but i wanted to give VIA another shot.
i have a kt600 and an n-force2 hands down get an abit NF-7s (not the g2) and a mobile 2x00+ and you will have a nice system
My KT600 board does 400MHz FSB just fine. It is designed for it. I have either decided to get the DFI Lanparty Socket A or the ASUS top of the line socket A board. Does anyone have any experience with any one of these?
Lyquist
Abit NF7-S, Asus A7N8X-E Deluxe, MSI K7N2 ISLR or Platinum version, I havent owned a DFI board, but i heard the Lanparty is a awesome board.
In that order is my choices....i would just look at these boards.
ABIT boards have had leaking capacitor issues on occasion (I've run into them myself), and ASUS boards aren't great for overclocking. MSI boards are fully loaded, but I don't know about overclocking options.
Anyway, if you plan to overclock, the DFI boards seem to be your best choice.
I'll recommend a VIA based board. I've had great luck with their chipsets for years, my current machine has the KT400A, and it's rock stable.
