Maybe some of you read my previous befuddled post, you could call it "the tale of a n00b and HVD SCSI".
In any case, today was my day of shining glory. My QLogic QLA1240D 64-bit PCI-X dual channel HVD SCSI controller arrived in the mail! Then I looked at the connectors on the board.
"Hey, these things are really small .... and thin ..... and hey, my cable doesn't plug into them! Hey, wait! WTF? ARGH!"
Some googling later, I discovered the connectors for this card are "VHDCI" SCSI connectors. My drives, and the cable I have, are apparently "HD" 68 pin SCSI, or just "the normal 68 pin kind".
If I fork over a ludicrous sum of money for an adaptor for VHDCI 68 pin to HD 68 pin, will it work without issue? I mean, it should just be the only issue is the size of the connector head: the cabling specs are the same for VHDCI and HD, right?
