VGA to RCA/SVideo converter problems
MadJuggla9
Ive got an xt6800gt with dual DVIs and s-video out. With this i intended on watching my desktop/movies/anything on my PC on my TV. I brought our test TV into my computer room and hooked up the svideo cable and the audio cables in via a mini-to-RCA converter. Everything worked fine and picked up great. It disabled my secondary DVI-out but that was expected.
I saw a VGA-to-svideo&RCA out converter on ebay for ~5 bucks. I thought, what the heck, if i get that, and a 50 foot RCA cable then i wont have to run my audio cables seperate from the S-Video out, plus I can just yank a monitor off at any time and hook the TV into it; Very handy. I hook it all up with 50ft of RCA and i get nothing but static, as if the video signal is not strong enough. I fool around with tv settings/refresh rates/force tv detection/resolution/etc ....
I also tried this converter on my GFs laptop using the alternate VGA output with an RCA cable. I tried my 5 foot RCA cables on both the PC and the laptop, neither seem to output to the TV correctly like my S-Video did instantly. Ive broken down to figure out that the direct cause is not the lack of signal strength in the bulky 50ft of RCA I got.
The s-video cable I have came with my vid card so I was unable to test the s-video output on my VGA converter due to the proprietary plugin to my video card. Should I just look for a long S-Video cable to attache to my current video card's cable and use regular car audio wire for audio signal outputs? The whole reason behind the adapter and long cable was to avoid having to run different cables, I wanted an all-in-one. Perhaps I need a more expensive vga->svid&RCA converter? Has anyone ever used one of these with success, if so, which one?
These cheap VGA to svideo/RCA cables won't work. They're made to use a proprietary VGA slot that has svideo/composite out wiring and since video cards don't have that these cables won't work.
This should have been stated in the eBay auction description (then again it is ebay that we're talking about).
But if you're running that much cable from your PC to your TV then you need to get a new TV. One that has DVI/HDMI cause with an analog cable (svideo) you're going to get a lot of signal loss meaning crappy image quality). 20ft is the most I would ever consider doing with an analog connection.
