So my laptop has a VGA out. If I use a VGA -> DVI converter and plug it into the DVI port of my Samsung 245BW will I get an improvement in the picture quality as opposed to using just the VGA cable?
No. You are simply getting a pin adapter for any reasonable amount of money.
DVI-I has pins to carry both an analog (DVI-A / vga) and digital (DVI-D) video.
All its doing is taking the vga pins, and putting them on the right DVI pins, its not converting anything.
That assumes your monitor even accepts analogue video over dvi, i think most only use the digital video portion of dvi.
(for price comparisons sake, an actual DVI-D to VGA converter is about $400 from gefen).
