VGA to Composite/New Receiver ?
john81
I am trying to help a family member out with his home theater room. I have some extra parts, enough to put together a decent HTPC.
Unfortunately, his home audio equipment is very nice, but dated (10 years or so). He has a Dennon receiver that is running to a projector via VGA out. The receiver he has only has composite in and my video card only has DVI out. I know DVI to VGA is fine but he has no VGA in, can I then go from VGA to composite?
Anyone know of any decent receivers on the cheap (I'm thinking Craigslist or something on sale for below $200) that would have a VGA and HDMI in, multi room, and decent sound quality?
Thanks
You mean component not composite right? If so then you can get adapters that go straight from DVI-I to YPbPr (Component). Composite is probably possible but that is going to be ugly, you're much better off just bypassing the receiver and going DVI-I to VGA to the projector. YPbPr is about as good as VGA for this purpose.
Finding a modern receiver with VGA switching is also going to be difficult.
Yeah, I am looking for DVI to component (red, blue, green). I read on some forums that DVI to component may not work. I have an old 8600gts that I am going to use with this build, do you have any recommendations on reliable DVI to component converter cable. Thank you for your help.
It might be a better idea to use a graphics card that comes with a component HD adapter.
Remember DVI is digital and component is analog, a simple adapter cable would not work, you would need a transcoder ($$$). And even if you extracted the VGA signal from DVI-I it still isn't the same as a component signal and you would still need a transcoder.
You're going to do some hairpulling with that setup, old equipment is hard to adapt to with modern equipment, but if you are willing to put in the time then have fun with the learning experience and good luck ;).
The 8600GT should have a component output available via a dongle from the 9pin (VIVO) jack that looks like an S-Video jack. The cable should have come with the card, if not then you can find one without too much trouble for a few bucks.
http://www.ebay.com/itm/260776350980 for example
