VGA Silencer on a 9800pro
69cents
I got mine about a week ago and I'm not very happy with the results. With the little 9800pro retail heatsink I was at 410/720. Now I'm at 408/715, I used AS5 but I did notice that the heatsink had really bad groves when it was surfaced.
Has any one lapped this thing? And what were your results?
VGA silencer
I lapped my silencer before I installed it. Dont' know what the temps were on my 9800 non pro before installation, but my max stable overclock was 416/350
After silencer installation I got up to 450/360
Originally posted by DJDishwateR
For some reason mine didnt work and killed my card, looks like I'm stuck with a GF3 now.
RMA?..
You probably chipped the PCB or something.
My Silencer installed very easily. My specs on my 9800 pro were 401/355 and after installation I get 412/371. For me, the 20 bucks was worth it. Plus the temp in my case has gone down around 5 degrees.
I dunno how people are having such a tough time with these things. I"ve taken mine VGA off and on I think at least 5 times since I got it and I haven't cracked or broken anything.
I didnt break or crack anything, I put it on and it the card didnt work, put the old heatsink back on, still doesnt work. I'm kinda pissed. I didnt take the shim off but I put enough AS3 to meet the gap which wasnt very much. Now it just doesnt work.
When I first installed it. I ran Atitool, started at stock speeds and it started dropping the core/mem down to like 300. I didn't know what the F was going on. I took it out of my PC, thing was on fire I swear. I tighten'd the screws a lil more. Then relized that I had it on "Low", The option should not even be on heatsink. and I'm sure the VGA silencer needs to be lapped.
You know who needs to make an awsome semi universal VGA heatsink? Alpha. PEP66-8045 their heatsinks seems to work the best for me. I had one on my 300A can't remember the name though.
