VGA Silencer Installation
Shieze
How easy is this really to install? I am seriously contemplating putting one on my AIW 9800pro. I am a little nervous about this, but I am pretty sure I can do this without any problems, will check to make sure I have good contact and such. Would just like some opinions, and is it worth it? They are cheap so not like spending $30 canadian is a lot.
If you can install a CPU heatsink, you can install the VGA silencer. There really isn't anything too hard about it, just make sure you don't tighten the screws too much, or not enough.
BTW vibecomputers has it on sale right now for $20 canadian. For $20 its not much of a risk at all. Even if it doesn't help overclocking very much, at the very least it will keep the temps down a little, and the hot air goes out the back instead of heating the case. Plus it looks cool.
Well I just looked at it and they want to charge me huge for shipping like $15 the cheapest, so forget that.
I can go downtown and grab one from bigfootcomputers for $30 so think will do that.
