Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am almost 99.99% sure that my 9800pro dun have a ship. I am pretty sure the guy I got it from took it off. My questions is, can I still install the VGA Silencer rev 3 if I have no shim on my 9800pro?
You run the risk of crushing the core by doing that. I wouldn't do it unless I could find another shim or improvise. A little rubber strip that you could glue to the PCB or to the Cooler itself might do it. I WOULD NOT try to tighten down that VGA silencer without a shim, because it will crush the core, and then no more nice video card.
